Survey123 Location Limitations
1006
11-23-2022 03:16 AM
EiderEtxeberriaNieto
I wanted to use Survey123 for a social study about safety in urban green spaces. I wanted the respondents to point on the maps which are the areas where they feel more safe or unsafe. However, I am encountering some limitations that might not allow me to collect the data as I planned:
  1. For every map, only one point can be selected.
  2. For every server, only one map can be used to collect geo information.
So, in the end, for every survey, I could only obtain one point. I was wondering if there is a way where I can collect more than one location per survey or if I could get some help with any other solution.
Thanks in advance,
JenniferAcunto
Put your map in a repeat. Users can then submit multiple points at a time. You can also include a select_one asking if users feel safe or unsafe in that same repeat so you can tie each individual points to a 'feeling'.
- Jen
MichelleWilliamsERM
To Add to Jennifer's comment, you might need to use the inbox feature if multiple people will be adding to a point.
