Survey123, Grid Theme, Required Astoria isn't showing
1020
06-01-2020 01:18 PM
MichelleWilliams1
Is there a trick to getting the * to show in the grid theme? Please see the attachments.
Tags (1)
BarbaraWebster1
Hi Michelle,
The value to indicate that a field should be required should be "yes" instead of "y". A list of the accepted values for commonly-used fields can be found on the types tab in the XLS form.
BarbaraWebster1
Hi Michelle,
