Survey123 Geopoint Info Bar
404
07-13-2018 12:52 PM
ShiraGerstein1
Is there any way to modify the bar under the map in the geopoint tool? I have some client requests to change the items included in the bar. I noticed that when I create a survey in the online tool, the altitude is missing.
Cheers.
Survey123 geopoint
JohnathanHasthorpe
Hi Shira,
In general, you can't modify the appearance of the geopoint questions in the Web App - apart from two exceptions:
1) Publishing a survey from Connect will add an altitude field to the question. This is because the created service supports altitude. Surveys created on the web do not support altitude, so the field is missing.
2) You can set the appearance value of a geopoint question to hide-input in connect and republish. When viewed in the Survey123 web app the question will appear with read-only coordinates, as opposed to the default coordinate input box. Note that this appearance value does not apply to the Survey123 field app.
Hide-input appearance for geopoint
Could you share the specific things you would like to update?
John
