We have implemented ArcGIS Enterprise (Server and Portal -DataStore) Installed .It is possible that you can update the information of our GDB in Oracle from Survey123 connected to Portal for ArcGIS to the teams that work in the field ?
Hi Kamilo,
Archiving is not required for a feature service to be supported by Survey123. It is enabled through the sync setting, along with the applyEditsWithGlobalIds setting; however, Survey123 only uses the applyEdits setting, not the full Sync workflow.
Hi Kamilo,
Yes it is possible to use Survey123 with existing feature services on ArcGIS Enterprise. Please see
for more information.
Hi James Do you know of some "step by step" to make the feature layer (with sufficient conditions : must have a globalid == enable sync when publishing your feature service) to be able to use it in a survey ? . The videos from UC (Ismael) and learning (http://learn.arcgis.com/en/projects/collect-hurricane-damage-assessments/lessons/create-a-feature-la...) already have the feature created.
Thanks.
Tutorial: Configure feature service data for offline use—Documentation | ArcGIS Enterprise , This could help from ArcMap, you just need to know the process from PRO
Hi Kamilo,
You should find the steps pretty much identical for ArcGIS Pro- the main difference is that some things that were a right-click in the Catalog window may now be a geoprocessing tool.
James , is necessary enable archiving previously in the feature class for my feature service ?
Hi Kamilo,
