Survey123 Filter Select_One Based on Date
2450
07-17-2017 08:28 AM
by Anonymous User
Not applicable
I have a date question at the beginning of the survey that is set to now(). I then have a select one question that ask for a species(Elk, Pronghorn, Deer). Each species has a different survey date range. Pronghorn are surveyed between Sept. 1-30. Elk are surveyed between Aug. 1-31 and Deer are surveyed year round.
Is there way to filter the species list based on the value in the date question?
JamesTedrick
Esri Esteemed Contributor
Hi Nikholai,
We currently can't do this with choice_filters in Survey123.  I've added this to better function support for the choice_list, which should cover this case (a filter check that the date occur betweens the start and end time).
by Anonymous User
Not applicable
Thanks James for the quick response!
Knecovska
Hi @JamesTedrick I was researching a similar topic and was wondering if this filtering dates in this manner is currently possible with Survey123. Thanks.
