Survey123 Feature Report - Omit content if certain fields are empty
822
10-03-2023 10:13 PM
Spatialelement
This feels like a simple issue but I just can't get the report to work.
All I want to do is use an "if" statement to either show or not show certain text if a field contains any text at all.
This is my current  approach. The syntax is validated as being correct, but I still get the empty categories showing despite their not being any value against them.
${if Themes_Environment != ""}Environment - ${Themes_Environment}${/}
${if Themes_People != ""}People - ${Themes_People}${/}
${if Themes_Economy != ""}Economy - ${Themes_Economy}${/}
${if Themes_Infrastructure != ""}Infrastructure - ${Themes_Infrastructure}${/}
Katie_Clark
Does it work if you just put ${if Themes_Environment}Environment - ${Themes_Environment}${/}
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
abureaux
MVP Frequent Contributor
I normally do what @Katie_Clark suggested for omitting empty fields, and it works very well (aka, I can't recall a case where it didn't work off hand).
I don't believe that it is necessary, but as an alternative is you could try string-length: if(string-length(${question_name})>0)
