Survey123 feature report not available
1091
04-08-2021 10:26 AM
TMaddio
I am having an issue loading a feature report for a few of my surveys.  The only way I have found a resolution is to rebuild the survey which is not ideal with surveys already in use.  I worked with tech support on this and now it is happening again.  It appears that the data is not loading even though I can see the data outside of the feature report. I try to produce a report and the window hangs indefinately.  Any ideas on what may be going on?  My data is in SDE/SQL published on our ArcGIS Server as a feature service.
TMaddio
This issue was resolved by following the steps included with this BUG:
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzODQ3NQ==
I added a hidden field and things started working.
This post was helpful:
https://community.esri.com/t5/arcgis-survey123-questions/data-not-loading-on-data-tab-in-survey123-o...
