Survey123 export to report failing due to timeout
512
06-13-2023 03:35 AM
AF2023
I am trying to export a report generated from a survey123 which was built using survey123 connect. The survey data collected is basic - just photos and comments, however there are c. 250 points and therefore 250 photos I want to export. There is only one record to export, so all 250 photos are associated with this record.  Every time I try to export the report, it fails due to timeout at about 9m 30s. I do not believe there is an issue with the report template, as it exports correctly when tested with 3/4 points.
Any help with exporting this report, perhaps in batches, would be greatly appreciated.
Many thanks,
Annys
CristianChavarini
We are having the same problem with our reports. The same happens when trying to edit a form from, for example, a dashboard.
Some time ago an update generated these same problems... I would like to believe that the origin is still the same...
Cannot export report (this post is about that)
