Survey123 Error with Calculation Bind Attached Unexpected Beginning
3305
02-18-2020 10:39 AM
BradGeorgic
Trying to use Survey123 XLSForm to do a calucation based on a  few fields inside the form.  I keep getting this error.  I have all the bind:esrifieldtype set to double.  the syntax for the p1distance field for the calculation is
(${EndPoint}-${StartPoint})/${Verticals}/2+${StartPoint}
Any help would be awesome!
by Anonymous User
Not applicable
Hi Brad,
Are you still having this error or did you resolve it? Can you share your xlsx file so we can take a closer look at the form design and calculations?
Regards,
Phil.
BradGeorgic
Yes still having problems. Thank you and I attached is the xls.  Any help is appreciated!
JamesTedrick
Esri Esteemed Contributor
Hi Brad,
A couple of things
- you may want to set the bind::type column of the calculate questions to ensure they have the appropriate data type while processing inside the form
- '/' is not the proper indicator for division in XLSForms; the appropriate keyword is 'div'
by Anonymous User
Not applicable
Hi Brad,
The problem is that the ${Verticals} question is a text question (by default all select one are text type even if they contain numeric values). You need to set the bind::type as int or decimal (depending on your numeric values in the field) and also in your calculation in ${p1 Distance} you can cast the values as int also.
Hope this helps.
Regards,
Phil.
BradGeorgic
THANKS  With a combination of these posts I got it
