Survey123 create ability to include media URL attachments as an attribute in CSV download
328
08-05-2025 06:47 AM
BrendanConway2
Survey123 create ability to include media URL attachments as an attribute in CSV download:
When using media data generated in the field by Survey123 (e.g. georeferenced photos), the media is visible in the map pop-ups created in Survey123, but is not visible if the data is exported as a CSV.
It is very desirable to be able to use the data as an exported CSV because the data can be reconfigured and additional attributes added as columns e.g. re-visits to fieldwork site; data from others about the same locations. This is particularly the case for educational uses, but almost certainly would apply to a wide range of other use cases. The reconfigured CSV can then be uploaded as a Feature Layer which can be used and updated in the usual ways. This would make Survey123 an even more powerful tool.
Suggestion:
Enable the CSV creation process in Survey123 to create an attribute column for Image_URL  (or for more than one image, Image_URL_1, Image_URL_2 etc)
BrendanConway2
Thanks Neal. Some helpful explanations and workarounds here. But a simple integrated solution is needed. The image URLs are easily accessible from the geodatabase so it cannot be difficult to integrate them as column(s) in the export CSV file.
Leena_Abdulqader
Hey @BrendanConway2, I would recommend adding your suggestion in the Survey123 ideas section.
https://community.esri.com/t5/arcgis-survey123-ideas/idb-p/arcgis-survey123-ideas
BrendanConway2
Thanks Leena. I did that a few years ago.
Survey123 is almost ten years old now and I made the image URL suggestion within a few months of its launch. So my patience is kind of wearing thin!
Updates in the pipeline so perhaps, perhaps?!
https://www.esri.com/arcgis-blog/products/survey123/announcements/announcing-the-next-generation-of-...
