Survey123 coordinates not displaying correctly
572
09-30-2024 02:37 PM
LizGibson
Kia ora,
I am using Survey123 to collect water quality data. The sites we are collecting data are pre-loaded into the survey so that groups select who they are and the location they are at, the latitude and longitude are then auto-populated for the site. For some reason, despite the latitude and longitude being correct, there is 6 surveys that have plotted at the same location. There are still being located in New Zealand so there is not an issue with the coordinate system there is some error with the survey. These surveys are all from different sites that have been plotted at the correct location on previous surveys.
Is there a way to force the data point to the correct latitude and longitude?
abureaux
MVP Frequent Contributor
As long as you provide a geopoint for data collection, there is always a chance someone changes the location.
You could always have a dynamic "lock" behind the scenes to turn the geopoint read_only if the survey contains specific data.
