Hello all !
I am relatively new to Survey123 Connect and am trying something that I can't seem to get right. I'm trying to filter choices based on the AGOL login (email). I read several threads and tried many things, but I think I'm simply missing one piece.
I have the login (email) passed through ok, but can't seem to get the choice filter to pick it up.
I have highlighted examples attached - I believe I should have received two choices; "Los Angeles" and "New York" in a drop down selection.
I appreciate the help. Thanks.
Solved! Go to Solution.
Hi John,
It looks like there's a slight mismatch between the e-mail you specified and the e-mail the tablet received:
- illinois (what you typed) - Illinois (received)
Because the choice_filter is doing an exact match, the capitalization matters.
Hi John,
You are correct. I've been staring at this all day. I appreciate your help.
