Survey123 Connect update creating issues with web form
7150
37
03-27-2026 01:15 PM
ChandraLala
Hi everyone, I was able to view my survey on the web perfectly fine before the recent update. After the update to Survey123 Connect (I am now using version 3.25.27), I receive an error message saying  "This survey cannot be opened in the web app. Please contact the survey owner to republish the survey with 'Create web form' enabled. Error: Missing .webform file." I can see in the survey files that a webform has definitely been created. I have tried republishing my survey and completely deleting it and publishing it as a new survey, and neither have fixed the problem.
I have experimented by removing certain parts of my XLSFormat table  to see if this fixes things. Removing certain questions and sections does fix the problem and allows for my survey to be viewed on the web, however this is not ideal because I need all sections and questions to be included. Please let me know if anyone else has experienced this and any possible workarounds.
EDIT: I previously thought this was an issue having to do with the update, though I was able to access an older version of Survey123 Connect and still experienced the same issues..
JodyZhengLiu
Thanks for confirming! Great to hear it's all sorted.
brierTurnbull
Had this issue as well in a long survey with a lot of pulldata()s, republished this morning and it looks like the hotfix worked Thanks for the speedy response.
JodyZhengLiu
Thanks for the confirmation! Glad to hear it resolved the issue.
LindaSlattery
We are having issues now well with surveys that have been live for over a year. Just upgraded to 3.25.27, updated the XLSForm template, republished, and still getting the error. Am I missing a step?
RalphPlummer
I've requested my organization to report this bug still exists since I do not have permissions to do so.  My survey behaves fine since it is only used in the field app but I have been trying to create a Power Automate Workflow using the ArcGIS Connector "When a survey response is submitted," and getting the error:
I came across this post and followed @ZacharySutherby suggestion about the webform file.  Being my surveys are too complicated for Web Forms; I didn't have one.  So, I enabled it and republished just to get the file.  I can confirm that the bug still exists and inside that file it reads:
  "error": {
    "code": -1,
    "details": [],
    "message": "Error: Entity expansion limit exceeded: 10012 > 10000"
  "success": false
 Before deleting approximately 50 to 60 rows from my survey that I did not want to delete, I was getting 10002 > 10000.  Afterwards I got 10012 > 10000.
I am currently on version 3.25.27 of Survey123 Connect.  Thank you.
JodyZhengLiu
Hi @RalphPlummer , thank you for reporting this. We will be deploying a hotfix to address the issue this coming Monday night (PST). Please try again on Tuesday or any time after. We appreciate your patience.
RalphPlummer
Hi @JodyZhengLiu, how is the hotfix coming along?  I checked and saw Survey123 Connect is still on version 3.25.27.  Is there a new approximate date I can expect the update?  Thank you.
IDEMuniMendoza
Hi everyone, is anyone still having problems with pulldata? Not only that...it seems to have caused problems with gdb...the services are failing. There's another post where is said that "The Survey123 documentation indicates that functions that use the pulldata("@geopoint") properties are not supported by the web application."
