Survey123 Connect Reverse Geocoding with Custom Geocoder
1526
06-04-2020 12:50 PM
DanteLee
Spatial references were never my strong suit, so sorry in advance if I use the wrong terminology somewhere
I'm trying to use a custom geocoder to reverse geocode a geopoint via pulldata. Our custom geocoder is in state plane, but the default World Geocoder is not. What's the way to handle this?
Side notes: We are only collecting data within our jurisdiction, and would like to match the address entered to our address point. This is a public survey, and we don't feel that teaching users to select the proper locator in the geopoint question will make sense to many people.
JamesTedrick
Esri Esteemed Contributor
Hi Dante,
Apologies for the delay in response.  Per, Reverse Geocode—ArcGIS REST API | ArcGIS for Developers , you can specify the output coordinate system by using the outSR parameter in the request; for Survey123 (which internally uses WGS1984), the correct code would be
outSR=4326
JamesTedrick
Hi Dante,
outSR=4326
DanteLee
Ah! Good to know. Thanks for the response. I'll give that approach a go. I'd ended up publishing a locator in WGS1984
