In Survey123 Connect (2.6.4) I'm struggling with getting the form to perform a calculation in a question only if I answer yes to an earlier question.
I have a select_one yes_no question ({samples}) which is "Did you take samples today?"
If the answer is yes, I would like it to generate a sample number (text, in the field sample_coll_no) which concatenates text that's already been entered by the user such as county code, target pest, and date. It has this in the calculation column: ${county}+"-"+${targetsci} ..... and so on.
So when, using the 'relevant' column, I make sample_coll_no relevant only when ${samples} = 'yes', or make the group that it's in relevant only when ${samples} = 'yes', it doesn't populate it in the form; there doesn't seem to be a triggering event that would make that happen.
If I make the 'relevant' column blank for the sample number question, it performs the calculation whether or not the "did you take samples" question is answered yes or no. And I don't want a sample number filled out when none was taken.
I'm not sure if it makes a difference but this survey is for filling in fields in a related table; the main point feature layer is trap locations and this related table is for the site visits; there will be multiple site visits for each site/trap.
Can anyone suggest a different approach to my problem? It seems like a somewhat standard thing that I'm trying to achieve but somehow I'm not getting there.
Thanks!
