I am using an existing feature service to build my survey using Survey123 Connect have added the .>now() constraint against a date/time field. However when I try it out, it is allowing me to enter a date/time before today and does not display the constraint message I have entered. Is there a known issue with this?
This should work - could you share the version of Survey123 field app you are using, the device make and model and operating system (including version).
Note that if you are testing in Connect - you will need to click the Validate Input button to check the functionality is working.
Thanks
John
Hi John, thanks for your response. I have since found that the date/time constraint is enforced at the end of the survey. I find this strange since another constraint I have against an integer field is enforced on data entry.
Michelle
I also confirm that for a DATE field, the constraint is enforced only at the end of the survey when you try to send the survey. I tested this on Survey123 for ArcGIS on windows 7 (Not to be confused with the Validate button in Survey123 CONNECT).
It would be great if this could be enforced sooner as a lot of my other constraint depends on the date.
Hi Michelle and Nicolas.
We have this issue open as an enhancement request and I will add your comments to it.
Thanks
John
Johnathan Hasthorpe, I'm having this same problem but with a decimal field (constraints not applied until I try to submit survey). This is a problem for me as I have a number of other fields that are calculated based on this decimal field, so the late constraint may come after allowing a user to enter a bunch of data based on the entered value that should have been rejected. I seem to remember that the constraints used to be applied immediately, which seems more appropriate.
Hi Evan,
Can you share your survey form and confirm the version of Survey123 you are using?
Thanks
John
Johnathan Hasthorpe, I have attached the XLSForm. As an example, constraints for fields such as NewDistance, NewBearing, TransectLength, etc. are not enforced until I either advance to the next instance of the relevant repeat or try to submit. This is a particular problem for DataStartPoint, as this value is used to calculate TransectDistance in the Point Intercept repeat, hence it is possible to enter a whole bunch of data in the latter repeat based on an erroneous starting value, as the DataStartPoint constraint is not applied until advancing to the next transect.
I am using Survey123 Connect version 3.5.157, Survey123 Android app version 3.5.164.
Hi Johnathan,
Can you please provide an update on the status of this feature? We, too, have a strong business case to have data validation occur instantly rather than waiting until the survey is submitted.
Please help, constraint doesn't work well after publishing the survey from survey123 connect. Since I design my survey in pages, I cannot proceed to the next page unless i choose another date for the date/time field with but still return with error.
I want the user to select date after 3 days from the day he fill out the survey here's the syntax (.>=(today() + (1000 * 60 * 60 * 24 * 3))).
I attached the xls form for reference. Thank you!
