Survey123 Connect Choice Filter
527
02-07-2022 08:44 AM
DevlinHutchins
I am having an issue with choice filters. I am experiencing an issue when I use it through a webapp. It works within fieldapp and inside coneect UI. No options in the list show on the webapp/url version. Please any assistance is appreciated TIA
DougBrowning
Might not be it but I see in your shot you named a field "number" but that is a reserved work.  See the little green box there in the name field is telling you it is a error.
DevlinHutchins
Doug -
Thanks for that tip. I will change it so I dont run into another issue with it. The issue I am having is with the question requested items. It is showing list in other formats but not in the webapp portion of it. It doesnt drop down with a list at all. I appreciate the reserved word note though!
