Survey123 change default Report Name using a REPEAT field name
1803
06-05-2024 03:19 PM
DeborahDennison
Hello, I could use some help with figuring out how to configure the Report Name using a ${field} in the report that is within a REPEAT.  The ${field} does work when I test a field that is not in a repeat.   Is there a specific syntax that I should use?
We capture a Tree Tag ID within a repeat that also captures a photo, health, description, etc.  I would like to name the Report with the Tree Tag ID number.
I read the documentation, but there is no information on handling repeat fields or limitations on using repeat fields in the Report Name.  I'm not sure if there is a limitation or if I am missing something.
I'm attaching images to see where this error is happening.
Here's the primary documentation: Print Survey Results Documentation:
https://doc.arcgis.com/en/survey123/browser/analyze-results/printsurveyresults.htm#ESRI_SECTION1_6D4...
If anyone has any insights it would be greatly appreciated!
Debbie
abureaux
MVP Frequent Contributor
You cannot use a repeat value in that "report name" field. There is only one report name and multiple repeat items.
If you pull a specific repeat "id" out of the repeat and then use that as the report title, it will work.
