Hello,
I know exist an attachment size limitation of 10 mb. but we are trying to add several attachments at the same time, they all are less than 10 mb, but if we sum them they are lime 23mb. so my question is, is there a sum size also when we add attachments? everything seems to indicate that the answer is yes because if I send the survey with no attachments, it send fine.
Thanks for your help.
DLL
Solved! Go to Solution.
The limit is per-attachment. In the mobile app, the max limit is 10Mb. In the Survey123 web app you can upload attachments up to 100Mb per attachment in ArcGIS Online, and up to 20Mb in ArcGIS Enterprise. more info in the Media help topic.
Gracias Ismael por la ayuda!
@IsmaelChivite Any chance this 10 MB limit can be upped? With the new 50 MP cameras out these are going to be over the 10 MB pretty easy. Also it means even at 720p I cannot send a video of more than 10 seconds! thanks
@IsmaelChivite I second Doug's thoughts. We already had to move our Survey123 forms from our Enterprise environment to ArcGIS Online because our attachments are frequently over 20MB. We need them in Enterprise though, not AGOL so then we have to copy the feature layer and attachments back. It would be so convenient to just upload surveys directly into Enterprise.
I agree with this as well. With phone cameras much better now, we run into issues submitting surveys all the time because of the 10MB limit.
Is there any movement to increase the attachment size for the Mobile App? i agree with other users here that this limit is far to small.
Because of this limitations we are thinking of alternative solutions to Survey123 such as FastFields or other SaaS vendors.
I can see a few work arounds but you then hit the 100/500 MB limit on the web forms as well.
