Hi
I'm new to the world of 123. I've got a task in mind that has this use-case
So far I've got a survey and on the Web version I can see the map, select a feature and edit it. But that doesn't seem to work on the mobile apps. Am I missing something?
What are your thoughts
cheers
ACM
Hi @AdrianMarsden2 , you can do it like this: Inspection Survey Using Survey123 only, w... - Esri Community
