Survey Thumbnail
9977
12
09-20-2019 12:39 AM
EricArmitage
How do I add a survey thumbnail in Connect?  I can preview it under the settings - general tab but when I publish the survey it goes back to the default.
Tags (1)
Shwu-jingJeng
Hi Eric,
What version of survey123 Connect you are using? And where are you seeing the default thumbnail with your survey?
After publishing the survey, the thumbnail should be seen from the field app download page, or the content page in Survey123 Connect(My Survey Designs) page. You will have to download the survey again to see the update thumbnail though (click the circle icon on the upper right coner of the survey).
EricArmitage
Hi
Its version 3.5.166.  This is the view before adding thumbnail
Preview before adding thumbnail
This is the preview with thumbnail before publication.
Preview after adding thumbnail photo
This is the overview after publication in Connect.  And obviously there is no thumbnail when it is downloaded to the phone.
View after publication
Shwu-jingJeng
Hi Eric,
I tried v.3.5.166 but could not repro the issue. I was able to see the thumbnail image after re-publish the survey. What image type/file size did you use to set your thumbnail?
EricArmitage
Its only 117 kb.  I've noticed that the download icon is constantly on for this survey in Connect and doesn't go off if I download again to the PC (see image above)  . Maybe that is related to the issue.
by Anonymous User
Not applicable
Hi Eric,
Are you using AGO or Portal/Enterprise, if so what version?
Based on the AGO documentation for item thumbnails here is the recommended details:
Images must be in PNG, GIF, JPEG, or BMP format; the image file will be converted to JPEG format before it is stored within the item's metadata. The recommended image size is 200 pixels wide by 133 pixels high.
Another thing to note is the image name and extension should be all lowercase (ie. myimage.jpg). We have seen issues before where uppercase or special characters in the name or extension can cause issues in Connect and the field app.
Phil.
EricArmitage
Hi Phil
Still no luck.  I renamed the file in lower case and also tried a different file but still wouldn't publish
Eric
Shwu-jingJeng
Hi Eric,
Are you using AGO or Portal/Enterprise to publish the survey?
EricArmitage
Hi
Its AGO.  Not sure about version number
EricaNova
This worked for me. Thanks!
