Survey not submitting - "Unable to complete operation"
3445
04-26-2021 08:35 AM
SeanLavallee__MES_
I had a working survey last week and now the survey is no longer sending records. There is no error code with the exception of "Unable to complete operation." Is there a general list of error that would bring up this issue? I attached the log for reference. This survey is on our Enterprise and is managed through SQL on our server. Thoughts?
Thank you,
Sean
Andrew-Bowne
Log in to ArcGIS Server manager and check the log files there.  They may reveal more info specific to your feature layer if the problem exists there.
SeanLavallee__MES_
Hi, this is helpful but does not reveal enough as to what is happening. We had a client who wanted to work offline and I am guessing changing the database layers of the feature service to be versioned and may have interfered with Survey123 reading the feature service....
Andrew-Bowne
Ah..   I am not sure that Survey123 supports versioned data.  Check out this doc on working with existing feature services...
https://doc.arcgis.com/en/survey123/desktop/create-surveys/survey123withexistingfeatureservices.htm
