Survey Description in Survey123 Connect
1986
02-12-2019 02:34 PM
JevaughnHenry
While using Survey123 Connect, how do I get the survey description to be displayed at the top of the survey as is available when creating a survey in the web designer of Survey123?
Is this feature only available through the web designer?
BrandonArmstrong
Hi Jevaughn,
You can add a note and add html in Survey123 Connect to serve as the Description.  One way to see how this looks is to download a previously created survey using Survey123 Connect that was originally published from the web.  As a precaution, I would do this with a test survey, as once you download a survey and republish with Survey123 Connect, you will no longer be able to use the Design mode for that survey in the web designer.
Best,
Brandon
BrandonArmstrong
Hi Jevaughn,
Best,
Brandon
JevaughnHenry
I tried this out your suggestion and it seems that the Note question type is how the description is displayed in the survey. Thank you.
