Survey data structure updating
2466
02-21-2023 07:42 AM
GregoireCatineau
Hello,
I have modified my table structure from Arcgis Online. I added a new field but it don't appear on Survey123 Connect. Is it possible to update the structure without create a new Survey Form ?
2 Solutions
GregoireCatineau
Thank you very much Rachel for your answer but it's don't work for me.
finally i am going to use ultimate solution : create a new survey and copy/paste from previous survey XLSForm.
RachaelMurtaugh
I've had to do that as well when I tried to edit the survey with appended data in it. You should be able to save the old survey with a new name to copy it.
RachaelMurtaugh
My experience is you can edit the survey in Survey 123 Connect and republish. That will add a new field. It might cause you to loose data, but it has worked for me in the past.
GregoireCatineau
RachaelMurtaugh
GregoireCatineau
Thank You Racheal for your help.
Grégoire
