Survey Data Not Saving in Inbox
3546
07-23-2021 03:10 PM
DustinBaumbach1
Hi Survey123 Community,
I recently created a new survey in the Survey123 Connect app (ver. 3.12) and have disabled the sent folder, instead opting for the Inbox so I can use the map refresh feature. However, when I send data from my form, I notice that the sent surveys show as blank in my inbox. Is this a bug? or is this a problem with my share settings? No data are saved after I hit the send button. Please see the attached screenshot. Note I have set the Instance_Name setting to display the patient ID, which is blank upon submission, even though an ID was entered when filling out the form.
Thank you,
Dustin
@JamesTedrick
Tags (3)
Alber_Verster
Hi Dustin,
Can you confirm that the record has been populated in your feature service? Possibly enable the Sent box for testing to see if the record sends ok and once you are satisfied, disable it and test again.
Regards
Alber
DeonLengton
Hi Dustin
Did you manage to fix the issue? If you are still struggling then please attach your survey XLXS file so we can have a look.
DustinBaumbach1
Hi Deon,
Thanks for checking back in with this. My availability to work on this project has decreased so I haven't been able to test it yet. I will definitely check back in and update everyone once I find out more information.
Thank you.
EricAdams1
I have a very similar problem to this. Has it been resolved?
