I have created a form for Survey 123 in Survey 123 Connect. The form works fine while in connect and now I am trying to publish the form to Arc GIS Online so I can access it from my device and use it.
When I press 'Publish' the wheel turns, it tells me it is Creating Feature Service with a code wkid=4326 and the wheel just spins and while the folder is created in my Online content, nothing is uploaded. What am I doing wrong?
Without more information, answering this is challenging. You might review the following for some initial guidance: https://doc.arcgis.com/en/survey123/desktop/create-surveys/publishsurvey.htm.
I've had issues with them hanging before and I deleted .iteminfo file and it published afterward. JUST TO BE SAFE, try making a duplicate copy of your survey, deleting the .iteminfo and seeing if it will publish the duplicate. Just something to try.
It seems that this issue might be the change from a trial version now listing me as a creator user type when I don't have a license for it, so it must be generating an error somewhere. Waiting to hear back from ESRI support, could be some time!
