Survey Check if Form Field Visible (Enabled)
553
06-30-2020 09:40 AM
RamseyHawasly
Hello, Using Connect- Is it possible to check if a field on the survey form is visible (enabled)? I'd like to perform some logic based upon whether or not a field is visible to the user (the field may or may not contain any values).  Thank you!
IsmaelChivite
Esri Notable Contributor
Hi Ramsey Hawasly‌. What if you use the same expression you already have in the relevant statement? For example:
typenamelabelrelevantcalculation
select_one yes_noyesnoYes or no?
textwhynotWhy not?selected(${yesno},'no')
hiddenisnotIs notselected(${yesno},'no')
RamseyHawasly
Thank you! What if I have a text field? Is it possible to determine if the text field is visible?
