Survey 123 phone number constraint
2071
6
12-14-2022 10:09 AM
fatihsonmez1
New Contributor II
How can I write a phone number without leading zeros, restricting it to 10 digits, are there any enhancement plans or constraint field code
For example: 5555555555
AmeWunderle
New Contributor III
You can add a constraint to the field. An example that esri gives is setting the constraint column to the following for phone numbers:
string-length(.)>=8 and string-length(.)<=12
You can also use a regex expression. Here's the suggestion from esri for emails for example (it won't let me paste it directly here so here's a screenshot):
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Guide/Regular_Expressions/Cheatsheet is a link to more information on how to formulate regex expressions
AmeWunderle
New Contributor III
You can also try for the phone number:  regex([0-9]{10}) which will limit it to 10 digits not just the string length
fatihsonmez1
New Contributor II
I tried but I get an error. I need to write this code in the constraint section, right? By the way, the question is in text format.
AmeWunderle
New Contributor III
sorry, you will need to change the syntax a little. The regular expression (regex) should include a (.,'()') for survey123 constraint so:
regex(.,'^([0-9]{3})(-)([0-9]{3})(-)([0-9]{4})$') if you want dashes
regex(.,'^([0-9]{10})$') if you don't
fatihsonmez1
New Contributor II
Thank you so much. I think I understand.
I try,
regex(.,'^(?!0)[0-9]{10}$')  if you correct syntax?
AmeWunderle
New Contributor III
Looks good to me. Test it out.
