Survey 123 or WebApp Builder?- Pull Data, Concatenate Fields, Avoid Duplicate
938
03-22-2021 08:04 AM
AlexP_
I am a bit rusty with survey123 and webapp builder. Please correct me if anything. I have ArcGIS Pro 2.7.1, sde, ArcGIS server, AGOL, map/feature service. Not sure which app is best to apply. I have a staff as an editor to create new point feature class. I have a few questions.
1)  set up pull data from existing polygon feature class parcel number field into point feature class in a parcel number field every time create a new point.  I saw something with geopoint or javascript from survey123? or is there a better other method?
2) how to set up concatenate fields ?
3) how to set up a field to avoid duplicate/repeat?
Please kindly advise. Thank you Alex
EDIT:
I haven't apply GLOBAL ID yet.
1)  set up pull data from existing polygon feature class parcel number field into point feature class in a parcel number field every time create a new point.  I saw something with geopoint or javascript from survey123? or is there a better other method? Are these info correct below?
https://community.esri.com/t5/arcgis-survey123-questions/pulldata-quot-geopoint-quot-location-quot-r...
https://community.esri.com/t5/arcgis-survey123-blog/understanding-reverse-geocoding-in-survey123-3-0...
Survey123 I found this link that might work for me. https://community.esri.com/t5/arcgis-survey123-questions/can-survey123-auto-concatenate-text-and-int...
I still can't find it. anyone kindly point this out for me? for example. not to reuse the same information in the field.
