Survey 123 Offline Upload Error
1954
05-11-2018 04:50 AM
CaseyHancock
After completing surveys on an offline iPad, when I connect to wifi and try to upload I am receiving an upload error: "Send Error - This survey was not able to be sent due to the following error: Do you want to be able to edit this survey?". I have tried clicking yes, then resubmitting, and I have tried clicking no to no avail. Any ideas?
JamesTedrick
Esri Esteemed Contributor
Hi Casey,
Can you sign out and sing in again in the application?  There is a known bug in logins expiring while offline.
CaseyHancock
Hi James: I am having issues both signed in and accessing the survey through a link. Our GIS specialist did some experimenting and it seems like our organizational account may actually be the issue - he was able to upload data collected offline with a survey built through a developers account, whereas all of our surveys generated through our org account are not working.
CaseyHancock
Hi again,
Just tried deleting and reinstalling Survey123 which seemed to do the trick. However, now I am worried about if this happens in the field and we lose all of our data! Any recommendations?
JamesTedrick
Hi Casey,
Uninstalling/reinstalling Survey123 shouldn't have had an impact (assuming this way the same version of the software before and after); though it should have forced a new login attempt.
CaseyHancock
Thanks! The login must have been the issue because offline data collection has been working ever since.
