survey 123 connect - issue with converting xls form
621
07-26-2017 03:07 AM
Jean-YvesLandry1
There seems to be an issue with the XLS Form converter.  I thought it might be an internet connection but it doesn't appear to be.
Jean-YvesLandry1
It appears to be working again, I recommend xls convert offline.
by Anonymous User
Not applicable
Hi Jean-Yves,
Yes, there was an issue with the API when publishing surveys from Connect containing pulldata(geopoint) and external selects. The issue has since been resolved and you should be able to publish surveys successfully. If you encounter any further issues please let us know.
Phil.
