Hi all,
I have a small formatting problem that I just cant seem to solve. If anyone has any ideas on what I am missing please let me know.
I have a survey and export that asks a questions. There are three answers you can give 1) the correct answer (yes, no , na) 2) the incorrect answer (yes, no, na)-> this conditionally prompts two other questions 3) A third answer where you don't directly answer the questions but write down Notes (essentially conditionally you get 1 additional question)
The survey works great. I am working on the feature export, each question is a line in a table (within word). I would like all the excess cells to not show up when not needed.
Here is a snip of my document. The results of this export are an extra row when the response is the correct one or the incorrect one.
I tried to solve this by putting the opening conditional statement behind the end of the previous closing statement ( same row) but I get an error stating "Error: The loop with tag "Q49== "Notable Observations" is unclosed. The loop with tag "Q49 == "Notable Observations" is unopened.
Thoughts?
Hi Olivia,
Is it possible to share the survey xlsx form and report template so we can have a test? You could sent them to zliu@esri.com. Thanks!
Best regards,
Jody Zheng Liu
Hello, Zheng
Do you have any updates on the error :The loop with tag "" is unopened ?
I wanted to modify feature report to my needs from the sample template created in Survey123 for my xlsx file, but I got the error with my templet saying Error: An error occurred when checking the report template. The loop with tag "" is unopened. So, I was trying few things, and the same error appeared every time. So, I renamed the sample template created by Survey123 to see if the original sample templet will give me the same error, and I redownloaded it, and I got the same error.
How would I overcome this error?
Thank you
I have the same "The loop with tag " " is unopened" error. Is there a way to resolve this?
