Survey123 v 3.14.237: does not retrieve data from FieldMaps existing polygons
653
03-16-2022 10:46 PM
ShuhratSh
After update to v.3.14.237 the Survey123 not able pull data from existing objects from FieldMaps map. Any idea how to sort it out
ShuhratSh
Hello @ZacharySutherby ,
Thank you very much. The issue is solved.
I use both - script for one form (which is working without problems), and include data into URL- the one was not working. First I removed the URL and used script but the result was the same. The issue is solved by now once we removed pulldata function from the form!
ZacharySutherby
Hello @ShuhratSh
Can you please provide some more information on your workflow? Are you linking to Survey123 and including data in the URL, or are you using a JavaScript function to request information from a feature service?
If possible would you be able to provide a video/screen captures showing the behavior?
Thank you,
Zach
ShuhratSh
