After running the analyze survey tool, I have multiple warnings about my html tags that say they are not supported, however, when I look up the ESRI docs, it says that they are. What's correct?
EDIT: okay, target is not supported. What happens if I leave it in? It still works on my machine...
Hello @AnnaScholl,
With the 3.18 release we have revised the messages to emphasize the attribute is the issue and not the tag. Leaving it in does not guarantee that it will work in both the Survey123 field and web apps, across all platforms, or in future releases.
Hello @AnnaScholl,
Hello @RichardPasquale,
The style nor target attributes are supported for the <a> html tag.
The error message is indicating the html attribute used is not supported.
