Supported html tags not supported?
1207
05-29-2023 06:15 AM
AnnaScholl
After running the analyze survey tool, I have multiple warnings about my html tags that say they are not supported, however, when I look up the ESRI docs, it says that they are. What's correct?
https://doc.arcgis.com/en/survey123/desktop/create-surveys/styleyourform.htm#ESRI_SECTION1_2BDD80200...
LydiaYoungblood_1-1685366082976.png|
EDIT: okay, target is not supported. What happens if I leave it in? It still works on my machine...
ZacharySutherby
Hello @AnnaScholl
With the 3.18 release we have revised the messages to emphasize the attribute is the issue and not the tag. Leaving it in does not guarantee that it will work in both the Survey123 field and web apps, across all platforms, or in future releases.
Thank you,
Zach
ZacharySutherby
Hello @AnnaScholl
Thank you,
Zach
RichardPasquale
New Contributor III
Zach,
I'm using 3.18 and still getting the forementioned warnings?
ZacharySutherby
Hello @RichardPasquale
The style nor target attributes are supported for the <a> html tag.
The error message is indicating the html attribute used is not supported.
Thank you,
Zach
