Summary reports with repeats
682
10-21-2020 03:05 AM
TragsatecJaén
Hi all,
I'm trying to create a summary of a Survey with repeat. I have created a script with correct syntax, but I can't generate the example report because of the following error: "Render expression is: ${#mySurveyname|where:"laver_name='option'"............."
The sintax what I used is the following:
$<$summary>
${#repeat}
${#mySurveyname|where:"layer_name='option'"|stats:"count,objectid,name":"layer_name2"|orderByField:"layer_name2 DESC"}${name}${layer_name2}${/}${/}
What's wrong?
Does anyone know how this type of script should be named?
Thanks so much.
David.
Tags (1)
BarbaraWebster1
Hi David,
Can you send your XLS form so we can look into this issue more?
-Barbara
