Struggling to produce a link that can be clicked in Fieldmaps to take you to a new form and autofill some fields
1228
07-07-2023 06:11 AM
EdHixson
Hi there
I have created a survey123 form to capture some information. This form then produces a feature layer which is accessible within fieldmaps. One of the fields is a link which can be pressed to open a new survey form and autofill some of the information from the point which had the link in.
This is the link I have produced but it doesnt seem to work
https://survey123.arcgis.app/surveys/1c1222a033d94022ab2512863870f0eb?field:swabid={Swabid}&field:assetid={Assetid}&field:Project_Code={project_code}
This link will open the survey123 app but wont open the specific survey with the auto filled values. I was wondering if anyone knew what I had missed from the link or whether having it as a read only field is the wrong way to integrate it into a feature.
Any help would be great
ATB
-Ed
DougBrowning
MVP Esteemed Contributor
The word surveys should not be in there  Also you are missing itemid part.
should be more like
https://survey123.arcgis.app?itemID=1c1222a033d94022ab2512863870f0eb&field:swabid={Swabid}&field:ass...}
try that. it is weird the http and app link are a bit different.
DougBrowning
To have it clickable inside the form the only way I got it is to use a note field and have the link in the label column.  Try that.
Also I think your format is off.  See this post  https://community.esri.com/t5/arcgis-survey123-questions/cannot-open-survey123-link-in-field-app/m-p...
EdHixson
Hi Doug
I have had a look at the link you sent and made a change regarding the & and ?. It doesnt seem to have helped though sadly.Anything else I am missing that I missed?
https://survey123.arcgis.app/surveys/1c1222a033d94022ab2512863870f0eb&field:swabid={Swabid}&field:assetid={Assetid}&field:Project_Code={project_code}
Also sorry for some confusion I am not trying to pretty the link within the form but with Fieldmaps from a popup
ATB
-Ed
DougBrowning
should be more like
