Status of Survey123 Connect 'Relevant' Webform BUG-000108880
992
03-21-2020 01:13 PM
Zach_Robinson
I've created a survey in Survey123 Connect that uses the 'Relevant' field to show/hide subsequent questions. I discovered after publishing my survey that the relevant expressions are not honored on the Survey123 website. A google search led me to BUG-000108880: Surveys created with Survey123 Connect for ArcGIS wh..
Is there a status update on this bug or a proposed workaround?
I'm using field calculations to compare a user's employee ID to their birthday for a COVID-19 health screening survey. If there's a match then they should be shown the relevant questions but this doesn't work in the website. I'd love to hear any proposed workarounds. Thank you!
James Tedrick ‌
JamesTedrick
Esri Esteemed Contributor
Hi Zachary,
This bug concerned the use of multiple choice questions in evaluating a relevant condition.  It was closed as due to form author error - the samples provided used an equal check to determine if a choice is selected; with select multiple questions, the selected(${q}, 'value') function must be used.
JamesTedrick
Hi Zachary,
