Spatial Query in Survey123?
1841
07-23-2021 09:09 AM
LeviCecil
I need to set up a survey where a user enters their address, it hits our custom geolocator and then queries an attendance boundary dataset associated with that point. Once the boundary is determined, the user will be able to make a choice between two schools for enrollment. Is it possible to add a spatial query to S123? Or could I accomplish this with Experience Builder?
DougBrowning
MVP Esteemed Contributor
This is coming in 3.13 which you can get from the Early Adopter site.  Look under Dynamic choice lists.
It was also covered at the UC.  See here https://community.esri.com/t5/arcgis-survey123-blog/arcgis-survey123-resources-from-the-esri-uc-2021...
I think it was on the Advanced one.
Hope that helps
LeviCecil
I downloaded the latest beta release and there is no search() appearance in the dropdown in Excel for select_one or select_multiple.
DougBrowning
no but you just have to type them in.
