Setting on to have others view surverys created
515
08-23-2021 09:44 AM
kborst
I have the settings set up for others to view other's survery's. I would want this to work via an app for the field to be able see others. I have previous surverys added on the Worker Map and on the Survery1234 app the survery does not show up.
ZacharySutherby
Hello @kborst
If you would like users using the Survey123 field app to view other submissions you will need to enable the inbox in Survey123 Connect for the survey.
Please use this link for reference regarding editing and viewing existing survey data: https://doc.arcgis.com/en/survey123/desktop/get-answers/editexistingdata.htm#ESRI_SECTION1_47C2CB834...
Thank you,
Zach
Thank you,
Zach
