Send information automatically with Survey123
1564
5
06-19-2017 09:30 PM
AngelAvila
There is some way that Survey123 sends the information that was raised without Internet and when device connects to the internet it sends it automatically
IsmaelChivite
Esri Notable Contributor
Hi. There are no hidden tricks for this. Surveys need to be sent manually by the user through the Outbox folder or by hitting the submit button.
JuliaStephens
Hi, are there any plans to add this functionality? e.g. an option to apply auto-send from Outbox when a WIFI connection is available?
JamesTedrick
Esri Esteemed Contributor
Hi Julia,
This is something we are looking into but can be tricky to implement- a device may receive a weak signal while out in the field and attempt to submit, leading to incomplete submittals.
JuliaStephens
If possible to link to only send when a saved/trusted wifi connection is active, that would be great.
IanGallo
Hi @JamesTedrick  - is this still the case? Manual upload needs to be triggered by user?
