Send error: Polygon input not valid
14244
21
01-17-2020 11:02 AM
JasonJordan00
I have a survey using geoshape however we are getting an error if we try to collect a new record.
"24305: The polygon input is not valid because the ring does not have enough distinct points. Each ring much contain at least three distinct points."
The polygons we are drawing *definitely* have more than 3 points. We have many records preloaded into the feature service and most of the work is done using the inbox. Updating those records has been no issue in the field.
Other surveys using polygons have worked without a problem. Any ideas? Thanks!
ThomasKukitz
Jimmy!
Hey great find! I had optimized my layer and the same error occurred. When I turned it off, as you mentioned, it works again! THANKS!!!!
Tom Kukitz
ThomasKukitz
One other thing is Esri should put in a note by the optimize button stating Survey123 will error if the layer is optimized.
Thanks again!
