Query a related table offline Survery123
2125
6
12-13-2022 07:09 AM
JJ_Reyes
I have an inspection form (related repeat table) that I am launching from the parent (related feature) point feature layer via Field Maps. I would also like to have the option for the user to pick a parent point in the form from a list instead of launching the form via Field Map popup.
I could use pulldata(@layer..... in the form to get the parent points. However, the survey might be used offline, so that wouldn't work.
The data is all in one feature service, which would all be available offline. Is there a method to accessing data in a different layer in your same feature service when you are offline?
DougBrowning
MVP Esteemed Contributor
Yes check out the FeatureSet functions in Arcade.  I do this often.  Call a related table to get an attribute then send that to the 123 form using URL parameters.
var tbl = FeatureSetByRelationshipName($feature, "Points", ['CollectCoreSubset1'], false);
return First(tbl).CollectCoreSubset1
Hope that helps
JJ_Reyes
Hmmm. I can use Arcade somewhere in the XLSX file? The user will not be launching Survey123 from a FieldMap. The user would be choosing the parent record to connect the inspection to in form in Survey123 app itself.
DougBrowning
Yes this is from Field Maps.  That is how me and others generally do it.  Use Field Maps to navigate to the correct location.  Tap parent, launch 123 form passing info to the child.  All works slick.
You could use the same concept in a 123 from though I think. Have a note field that is a URL to launch a child form passing over the key and any other info you want from the parent form.
JJ_Reyes
I see how that could work. I'd have to have a parent and a separate child form. I think the point is that there is no way to access the parent data from within the child form when offline? (even though they are in the same feature layer that would be downloaded to the device?)
DougBrowning
Correct I do not think you can query the local DB on the tablet.  Maybe with javascript?  I have not seen that done though.
JJ_Reyes
Me either. It looks like this solution would have to be online.
pulldata("@javascript","get_globalid.js", "findCode", 'https://services1.arcgis.com/1acZBnEF9zjV0l5X/arcgis/rest/services/Building_Data_Test3/FeatureServer/0', string(${NAME}), 'GlobalID')
