Select_one select_multiple duplication bug
399
07-30-2024 09:03 AM
abureaux
MVP Frequent Contributor
This is apparently still a bug:
Lists are getting duplicate (or more) items after publishing updates.
Not sure of the cause as it seems random and varies person to person.
DanPatterson
this bug?
BUG-000128282 for ArcGIS Survey123 (esri.com)
or one of the others
Esri Support Search Results
the status for each is listed
... sort of retired...
abureaux
Unfortunately not.
But found it here (In Review since January 2022): BUG-000146024 Survey123 Field App does not remove Choices that were updated in Survey123 Connect.
