Select_one from One of Two Lists
739
10-12-2022 10:41 AM
STezak
At times during our field survey we will know the permit number, at other times we will know the record ID. I would like to pull data using either the permit number or the record ID, without having a prior question. At present I have the two select_one questions in a grid format (side by side), and can choose to pull data by permit number and record ID (image attached). I'm able to get the results I want, knowing not to select from both select_one questions. Is there a way to set up a select_one questionA or select_one questionB without answering a previous question?
Thank you,
Sage
MichelleWilliamsERM
Hello, if the numbers for both answers don't overlap each other, can you add them all to the 1 question? And the question could be - Choose permit number OR record ID.
I hope that helps.
STezak
Thank you. That is definitely an option. I appreciate your time.
Sage
