select_multiple_from_file External choices
4990
10
06-08-2021 05:28 AM
YuliaMamonova
I have a form where I have select_one_from_file question, which is pulling choices from external CSV - It's been published and works fine. I am trying to change this question from select_one_from file to select_multiple_from_file and after saving the form XLSX the survey is converted with no errors, but then it shows it's optimizing and never finished, just keeps spinning.
Any thoughts?
Thank you,
Yulia
Tags (1)
YuliaMamonova
Hi @IsmaelChivite @JamesTedrick ,
Could you please help? External choice list only works with select_one_from_file question, but when I change the question to select_multiple_from_file question, the form starts spinning and then is being optimized endlessly. The choice list is over 60,000 values.
I appreciate your help!
