Search() Appearance wrong integer filter
1539
10-08-2023 03:12 AM
OfraAi
I have a survey created using Survey123 connect on ArcGIS Online.
I select city from list in the 'choices' tab, and have to select station, from feature service table, filtered by that city.
The ${CityName} column has a domain value, that is Integer and label as string.
I use autocomplete search:
autocomplete search("STList?url=https://utility.arcgis.com/usrsvcs/servers/xyz/rest/services/Servicename/MapServer/1","matches", "CityCode",${CityName})
I've created the survey a long time a ago and it worked perfect! Few months ago it stopped filtering the list.
When I check the survey in browser and F12, I see that the rest query created contains:
(name IS NOT NULL) AND CityCode = '182'
The column is integer and the filter value is string, so the query fails!
In XLSX the CityName is defined as esriFieldTypeInteger, so does the column CityName in the survey feature service, and in the table feature service for the list.
What causes the survey to create string value, how can I change it.
Thanks for any help
Ofra A
IsmaelChivite
Esri Notable Contributor
OfraAi
Do you have any idea, and can help me?
@ZhifangWang @ZacharySutherby
ZacharySutherby
Hello @OfraAi
Apologies for the delay, I've created internal issues for not sending the integer value as a string. It looks like this issue only impacts map services and does not impact feature services. As a workaround enabling feature access (read-only is fine) on the service will resolve the issue.
Thank you,
Zach
OfraAi
Hello Zach,
The survey service is based on feature layer, in order to collect data.
The dynamic data layer is access as feature access, with /1 at the end:
I did not understand what you mean
Regards
Ofra
