S123 web not honoring bind::type entered in connect
100
Thursday
JAbbott
I'm working on updating accepted file types using Survey123 Connect. I've updated the types in Connect (and they work when demo'ing in Connect) then I publish to the web and the changes aren't reflected in the web form. I even wiped out all file type restrictions, and it's not honoring that when publishing.
Is there something I need to do to force the accepted file types to update? Is this a known issue?
Thanks.
Neal_t_k
if you are referring to a file upload question and limiting what types of file can be uploaded, the column you want to adjust is body::accept
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformmedia.htm#ESRI_SECTION1_A2F2DA5ADD...
