S123 Power Automate ArcGIS Enterprise URL Error
1016
03-03-2023 07:50 AM
joncroley
I am receiving an error where I cannot create a new power Automate flow due to a requirement for an ArcGIS enterprise url. I never needed this in the past and we are and AGOL agency. This also keeps me from being able to edit existing flows.
ZacharySutherby
Hello @joncroley
This is a defect with the Survey123 templates in Microsoft Power Automate. This has been logged as BUG-000155504.
To work around the behavior either remove the Survey123 connector and readd it or select My flows > New flow > Automated cloud flow and select the Survey123 connector.
Thank you,
Zach
joncroley
It worked for 4 flows and then I started receiving the same error again.  Even adding a new flow connection does not work.
