Restricting repeated features in Survey123
848
04-25-2018 09:09 AM
GabrielGarcies_Ramon1
Hi everyone,
Would it be possible to restrict the survey to just 1 form for each feature ( 1 ID = 1 form). For instance, not being able to choose the same area (A03_Z1) once it has been previously populated.
Thanks in advance,
Gabriel - Sorigué, Barcelona
RenatoSalvaleon
I believe this requires the search(_) function so its not supported yet until Cascading Selects feature is implemented.
I'm already using Cascading Selects between the first 2 fields in this survey. Still not possible to do what I need?
Cheers!
James Tedrick
JamesTedrick
Esri Esteemed Contributor
Hi Gabriel,
This could be done if you create empty records (one for each feature) for the features beforehand and use the Inbox to have this be an editing workflow.  Otherwise, as Renato mentioned, this would need to have a search() function (extended to scan either the feature service or possibly the user's sent folder), which is currently not in Survey123.
